mainhattan
Sep 16, 2021Aspirant
Bad performance Orbi RBR20 with Unitymedia / Vodafone Station
Hi, I am using a Vodafone Station with an Orbi20. Lately the wifi performance has dropped from about 200 to 50, whereby I signed up for a 500 line. Please advise if you are experiencing simil...
Sep 16, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
mainhattan
Sep 28, 2021Aspirant
FURRYe38 wrote:What Firmware version is currently loaded?
V2.7.3.22
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Vodafone Station
130 sqm
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡app. 10 meters each
no changes
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settingsno changes
- FURRYe38Sep 28, 2021Guru - Experienced User
So does the ISP Modem have a built in router and wifi already?
Do you have Armor or Circle enabled on the RBR?
- mainhattanSep 28, 2021Aspirant
FURRYe38 wrote:So does the ISP Modem have a built in router and wifi already?
Yes, it does.
Negative
- FURRYe38Sep 29, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
