dmc0815
Jan 03, 2019Follower
Bad performance with Fios
My original setup was Fios Router (g1100) -> Netgear Orbi Router in AP mode. I changed the Orbi to Router mode and disconnected the Fios Router. Performance was good with the original setup, but is horrible with the new setup. I went with the new setup figuring it would increase performance.
I have Fios Gigabit and I am getting 50Mbps in areas I was getting 250-300Mbps before. Is there any setting on the Orbi I need to change?
Try a factory reset on the ORbi router and setup from scratch. Be sure to not enable QoS, Traffic Meter or Access controls. These seem to slow down Orbi on 1Gb services.
- ekhalilMaster
Just to exclude the radio factors and settings, what speed do you get using a wired device or using the Orbi built-in speed test?
