Dgfamilypa
Feb 12, 2021Aspirant
Bad speed tests when using Orbi RBR40 WiFi
I have an RBR40 router I have Verizon fios gigabit service When I connect to the Verizon WiFi I get speeds of down 377 up 286 When I connect to the Orbi router WiFi I get speeds down 93 up 92 ...
vajim
Feb 12, 2021Master
Are you running the routers at the same time?
- DgfamilypaFeb 12, 2021Aspirant
vajim I am, I have the verizon router with wifi on and the Orbi with wifi on but we only connect to the orbi. My understanding is we have to use the verizon router as the Modem
- vajimFeb 13, 2021Master
Dgfamilypa wrote:vajim I am, I have the verizon router with wifi on and the Orbi with wifi on but we only connect to the orbi. My understanding is we have to use the verizon router as the Modem
If you don't need the Verizon router get rid of it
if you run both one has to be the router while the other is a access point
