May 30, 2018Guide
Baffled by poor wireless performance
Hi Everyone,
I've had my RBK50 setup for just over a month now and have had nothing but problems.
I've now resorted to disconnecting the RBS50 satellite and moving the RBR50 to the centre...
st_shaw
May 30, 2018Master
Something is wrong there. Orbi can support more than 500 Mbps throughput.
What app or website are you using for your speed test?
What make and model client device are you using for your speed test?
Do you have a Mac or Windows laptop with an 802.11ac WiFi adapter you can test with?
