May 30, 2018Guide
Baffled by poor wireless performance
Hi Everyone,
I've had my RBK50 setup for just over a month now and have had nothing but problems.
I've now resorted to disconnecting the RBS50 satellite and moving the RBR50 to the centre...
May 30, 2018Guru - Experienced User
Is WMM enabled on the router?
Test with a different wireless device...
Test both wireless and wired speeds...
018125
May 30, 2018Guide
I test using the Speedtest.net app or web site and I’ve tried various different local servers.
I’ve test from my iPhone 7, my MacBook Pro and my wife’s Galaxy S8. Same results.
If I plug an Ethernet cable into my MacBook I get the full 74mb download. If I switch to wireless even while right next to the RBR50 it drops to 37ish.
WMM is enabled.
WMM is enabled.
- 018125May 30, 2018GuideOk I just noticed the Orbi app is showing that my iPhone 7 has a link rate of 54 mbps and my MacBook Pro has a link rate of 36mbs.
This is on 5Ghz while I’m sitting next to the router.
I wonder why the link rate is so low? - st_shawMay 30, 2018Master
OK. Use the MacBook.
What year and model is the MacBook?
On your MacBook Option-click on the WiFi icon at the top of your screen. Tell us the reported values for Channel, RSSI, Noise, TX Rate, PHY Mode, and MCS Index.
- 018125May 30, 2018GuideThank for for your assistance.
It’s the latest MacBook Pro bought a couple of months ago.
Channel: 36 (5Ghz, 20Mhz)
RSSI: -19 dBm
Noise: -99dBm
TX Rate: 54Mbps
PHY Mode: 802.11a- st_shawMay 30, 2018Master
The link rate is your problem. I have a MacBookPro from 2011 and I show a link rate of 300 Mbps, which is as fast as the old MBP will go.
Your RSSI looks abnormally high. Mine is -47 and I'm 10 feet from the Orbi with nothing in between. You could be too close. Try moving 10 feet away and see if the link rate improves.
Also, your channel report looks off. You should have at least a 40 MHz channel width, not 20. Lower channel width will give lower speeds.
Either something is misconfgured or broken in your Orbi, or you have another wireless device causing interference and forcing Orbi to operate at a low link rate and 20 MHz channel width.
When you did a factory reset, did you reset using a paperclip and did you hold it in until the power LED flashed Amber?
Do you have any other WiFi routers, wireless speakers, Sonos, wireless video links, etc. in the home?
