Mestegall
Aug 03, 2017Star
Bandwidth monitoring by device
Hello all! I was wondering if anyone has found out how to organize and/or prioritize bandwith by device for the ORBI system? I have found a way to enable QoS, but have not found a way to set the ...
st_shaw
Aug 03, 2017Master
Quality of Service router settings won't help your WiFi signal. Can you move one of the Orbi units closer to the camera, or move the camera closer to the Orbis?
- MestegallAug 03, 2017Star
I have relocated it already so that it is literally 10' from the orbi satellite device. It's basically as close as I can get it.
- st_shawAug 03, 2017Master
Are you sure the camera is connecting to the closest Orbi? You might need to reboot the camera to get it to connect to the strongest signal.
Thank you for your suggestion, however I've rebooted the camera multiple times to try to maintain the signal.
- peteytestingAug 03, 2017Hero
as suggested it may be only 10 feet from the orbi but whats in its way in those 10 feet
Thanks - but there is nothing between the orbi and the camera - they are in direct line without any obstructions and ~10 ft. apart.
Thanks however, for all the suggestions! Keep them coming!
