Mestegall
Aug 03, 2017Star
Bandwidth monitoring by device
Hello all! I was wondering if anyone has found out how to organize and/or prioritize bandwith by device for the ORBI system? I have found a way to enable QoS, but have not found a way to set the ...
Mestegall
Aug 03, 2017Star
Thank you for your suggestion, however I've rebooted the camera multiple times to try to maintain the signal.
st_shaw
Aug 03, 2017Master
Distance isn't necessarily what matters--it's what's between the camera and Orbi. You haven't described that. If there's a stone wall, metal siding, cinderblock, etc. in between, it would block the signal. You might need to move the camera so it has clear line of sight to the Orbi, maybe through a window.
If there's nothing between the Orbi and camera, then maybe there's an issue with the camera.
