Mestegall
Aug 03, 2017Star
Bandwidth monitoring by device
Hello all! I was wondering if anyone has found out how to organize and/or prioritize bandwith by device for the ORBI system? I have found a way to enable QoS, but have not found a way to set the ...
peteytesting
Aug 03, 2017Hero
Mestegall wrote:
I have relocated it already so that it is literally 10' from the orbi satellite device. It's basically as close as I can get it.
as suggested it may be only 10 feet from the orbi but whats in its way in those 10 feet
Mestegall
Aug 03, 2017Star
Thanks - but there is nothing between the orbi and the camera - they are in direct line without any obstructions and ~10 ft. apart.
Thanks however, for all the suggestions! Keep them coming!
