NewbyOldguy
Jun 15, 2021Aspirant
Bandwidth/Picture Resolution fade in and out
Not sure of the model...router is RBR40...triband. No questions seem to be quite like my issue. The Orbi Mesh is awesome but still has a issue I would like to understand. When watching TV, period...
- Jun 16, 2021
Ask the ISP about disabling the wifi radios on the ISP modem. Most most have this ability to disable there radios.
Sounds like you have WAY too much wifi signals running about and is causing problems.
Jun 16, 2021Guru - Experienced User
NewbyOldguy
Jun 16, 2021Aspirant
I will give that a try. I will also, as was suggested, turn Orbi off and see what happens to the picture.
Thanks for the suggestions.
Stay tuned for a follow up on results.
OldGuy
