mwhaley99
Jul 11, 2018Aspirant
Battery drain on my iOS devices
I noticed that my iOS iPhone's/iPad's battery drains MUCH faster when I am at home on my home Orbi wifi network.
I thought it may have been an issue with my previous house (walls, interference ...
Jul 11, 2018Guru - Experienced User
What FW version are you using?
What iOS versions are you using?
Try setting a IP address reservation for your devices on the router.
Try using manual channels 1, 6 or 11 on 2.4Ghz.
Disable MIMO, Daisy Chain and Fast Roaming on the router, apply settings and reboot.
- mwhaley99Jul 11, 2018Aspirant
v2.1.4.16
iOS 11.4
I made the changes you suggested and will see how it goes. Thanks.
