cyberguts
Dec 01, 2019Aspirant
BBC iPlayer not working with Orbi RBK50 + DM200
Recently purchased a new DM200 Modem and Orbi RBK50 to replace my D7000 setup. I've set up the DM200 into Modem Mode with latest FW installed, Orbi in Router mode and have latest beta FW installe...
cyberguts
Yes, DM200 is in Modem Only mode
Orbi Router is running as 192.168.1.1
Youview Box is detecting Orbi Router as 192.168.1.1, and I've assigned a static IP to the YouView Box.
Like I said, everything works perfectly fine; and obviously ran Orbi as Router as to me DM200 as M+R seemed pointless when all the features of Orbi are newer and better.
What draw backs would I have if I enabled DM200 as M+R and Orbi as AP? Just to fix this issue?
Dec 01, 2019Guru - Experienced User
Might try the DM modem in router mode and configure the Orbi for AP mode and see if this changes behavior...
Whats this YouView box? Static assigned IP address meaning reserved IP address ON the Orbi router for this device?
If the DM modem is in modem mode, then the IP address see on the WAN side of trhe RBR should be something like ##.##.###.### and not anythink like 192 or 10.
