Stormer077
Jan 05, 2017Aspirant
BBC iPlayer not working with Orbi
Hi - I just purchased an Orbi system which seems to be working fine apart from BBC iPlayer now doesn't work on my iPad. When I connect to the gateway router using its own wifi hotspot directly it wor...
dmw_2
Jan 09, 2017Guide
I have recently installed Orbi and Satellite and have multiple connectivity issues, one being BBC iPlayer through a Samsung Smart TV (wired and wireless). It's a similar issue through the iPlayer app on a YouView box (wired). I manage to connect to iPlayer via wireless from an iPad OK, then try to cast via Chromecast to the TV and it fails. I have similar issues with Netflix although Amazon Prime video is faultless. I have connectivity issues with my British Gas Hive Hub which connects for a short while then goes off line. I have used all these devices and many more with a Nighthawk D7800 for a couple of years with no issues at all. I have a lot of experience with Netgear routers but never like this. I have extracted the logs from the Orbi but nothing in there to suggest an issue.
