RegDawg
Apr 19, 2018Apprentice
Beam Forming and MU-MIMMO
I noticed these options unchecked along with "fast roaming" (I think thats it) in the UI. Should these be checked for better performance?
Apr 19, 2018Guru - Experienced User
You'll have to test them out to best suit your needs. If you don't any or many MIMO supporting devices, then you can leave MIMO disabled.
I have Beamforming enabled and all is working well with my devcies.
