PhoenixV
Nov 20, 2016Apprentice
Beamforming and MU_MIMO default settings
I noticed a change in the defaults for MU-MIMO and Beamforming. Prior to upgrading to 1.3.0.26 firmwate, these were checked by default. In 1.3.00.26 the default has been changed to unchecked? Does an...
peteytesting
Nov 20, 2016Hero
yea it will ve the case that if you upgrade the firmware but do not factory reset afterwared the nvram isnt cleared and thus you retain your current config
if however you factory reset after upgrade the nvram will be cleared and the default config at startup is used and by default both mu-mimo and implicit beamforming are disabled
PhoenixV
Pete, this seems to be a change from the previous defaults. I seem to recall that prior versions had these options checked? Why the change? Any insight?
- peteytestingNov 20, 2016Hero
hi
its to do with compatibility with some of the IoT devices like ring door bell and a few others that wont connect with these enabled
if you dont have any issues with clients mis behaving and or refusing to connect etc you can enable them without issue , older apple devices can also exhibit these issues
i have them enabled here and it improves coverage so will leave them **bleep** way
peteytesting wrote:hi
was meant to read
i have them enabled here and it improves coverage so will leave them that way.
spell check and abuse filter getting confused once again lol.
