jay540
Jan 28, 2020Tutor
Beamforming and MU-MIMO Disabled by Default
I purchased my Orbi yesterday and setup in AP mode after much trial and error. Everything seems to be running fine. I have Fios as my ISP. My firmware on both the Orbi router and satellites were upda...
- Jan 28, 2020
Beamforming should be enabled. Helps in wifi performances.
MIMO is for devices that support MIMO and mostly it can be enabled. In recent past few years MIMO devices have become more prominent and on wifi routers. If you don't have any MIMO devices this feature can be disable. https://www.smallnetbuilder.com/wireless/wireless-features/33100-why-you-don-t-need-mu-mimo
wase471111
Feb 13, 2020Apprentice
I just talked to netgear, and they told me on the rbr853, and on all wifi 6 orbi priducts, beamforming and mumimo is ENABLED by default; it comes on automatically when used/needed,and there is no where in the web interface to turn it on or off...
Feb 13, 2020Guru - Experienced User
Yes, for the 8 series Orbi, Beamfroming and MIMO are not seen in the UI.
Please be sure to post about any Orbi 8 series systems over in the Orbi AX forum
Thanks.
wase471111 wrote:I just talked to netgear, and they told me on the rbr853, and on all wifi 6 orbi priducts, beamforming and mumimo is ENABLED by default; it comes on automatically when used/needed,and there is no where in the web interface to turn it on or off...
