MikeP63
Apr 14, 2025Follower
Best Cable Modem for an RBR40
I am trying to replace my Comcast rented router with my own Router. I purchased a Arris Surfboard 8200 and could not get my Orbi to work at all. Had a good hardwired connection. Tried everything f...
Apr 14, 2025Guru - Experienced User
See if NGs CM series is on the list. I know CM3000 and CM2050v are supported on the higher speed tier. If you don't need the higher speed tier, check on NGs CM1000, 1100 or 1200 series modems. These are good modems for lower speed tier.
MikeP63 wrote:
I am trying to replace my Comcast rented router with my own Router. I purchased a Arris Surfboard 8200 and could not get my Orbi to work at all. Had a good hardwired connection. Tried everything for 2 days with no luck so I put the Comcast router back on.
Anyone have a recommendation for a very compatible cable modem? Obviously do not need the wifi as I run everything thru the Orbi
I returned the Arris to Best Buy.
