b1o3o
Sep 28, 2017Aspirant
Best Configuration/Settings for Orbi and Spectrum
Just got Orbi main hub and one of the satellite and Spectrum broadband. Main hub is connected through Spectrum's Gateway device. I peak at 118mbps (which is the fastest Spectrum offers) if I'm in the...
b1o3o
Sep 29, 2017Aspirant
Thanks!
So I went on ahead and logged on my Gateway and turned off it's WiFi capabilities. And the device now has 2 of it's lights off to confirm.
I have my Orbi on AP mode, and punched in Google's Primary and Secondary DNS. Is this (or Open DNS) a good move? Or should I just use the dynamic DNS from the Gateway?
As replacing my Technicolor Router, I just started their 1-year introductory service. I don't even see in the bill if and how much I'm getting chatge for leasing the device.
Any other settings/configurations I should do in the Orbi? Or Gateway?
Thanks!
loomis1975
Sep 29, 2017Luminary
Unless you are having internet name lookup / DNS issues, I think the default works fine for most use cases. I use OpenDns because its free and allows me to do some easy blocking/filtering of things. I have used it with a bunch of Netgear routers and others and several Mesh Wifi systems (mostly Orbi and Linksys Velop) and it has worked fine with them all.
I am unfamilar with the Technicolor router. But if its standard old Charter Spectrum cable internet and not some different subsidary or merged/aquired business unit (Time Warner Cable comes to mind), there is no monthly fee for cable modems, but there is a monthly fee for a modem/wifi router gateway device. This might kick in after the introductory period.
Most of the standard settings are fine, gives you less to troubleshoot later. :) I would obviously change the password for your router/satellites access from the default.
You could also play around with the 2.4 ghz power tranmission level if you feel you are having issues with devices not ever switching from satellite to router or vice/versa when you think they should be. I would think you would have to have your router and satellite way too darn close together to have to consider lowering the 5.0 ghz power transmission level.
