b1o3o
Sep 29, 2017Aspirant
Best Configuration/Settings for Orbi and Spectrum
Just got Orbi main hub and one of the satellite and Spectrum broadband. Main hub is connected through Spectrum's Gateway device. I peak at 118mbps (which is the fastest Spectrum offers) if I'm in the...
loomis1975
Sep 29, 2017Luminary
Unless you are having internet name lookup / DNS issues, I think the default works fine for most use cases. I use OpenDns because its free and allows me to do some easy blocking/filtering of things. I have used it with a bunch of Netgear routers and others and several Mesh Wifi systems (mostly Orbi and Linksys Velop) and it has worked fine with them all.
I am unfamilar with the Technicolor router. But if its standard old Charter Spectrum cable internet and not some different subsidary or merged/aquired business unit (Time Warner Cable comes to mind), there is no monthly fee for cable modems, but there is a monthly fee for a modem/wifi router gateway device. This might kick in after the introductory period.
Most of the standard settings are fine, gives you less to troubleshoot later. :) I would obviously change the password for your router/satellites access from the default.
You could also play around with the 2.4 ghz power tranmission level if you feel you are having issues with devices not ever switching from satellite to router or vice/versa when you think they should be. I would think you would have to have your router and satellite way too darn close together to have to consider lowering the 5.0 ghz power transmission level.
b1o3o
Sep 30, 2017Aspirant
The Google DNS seems to be reliable. Unfortunately, Technicolor is still running on the original DNS, and I'm still trying to figure out how to change that. But so far, thanks to your advice, I haven't seen any intermittent dip in speed. I'll check tonight since the crawl happens late at night.
The majority of my devices are running on 5G. Actually only 1 device, my Kuna security cam, is on 2.4ghz. But they're all powered by Orbi. So it's safe to say that Orbi is running both 5G and 2.4ghz at the same time. Correct? And the Orbi main hub + satellite is strong enough to cover my entire house with 5G speed. Actually, thinking about getting 2 more satellites just to cover some deadspots only noticeable whenever I have a gathering.
I'm gonna keep messing around my settings to figure out where the transmission levels are. Thanks again.
