Interested13
Jun 12, 2020Follower
Best extender to get and how hard to install?
Hello - I'm not an IT specialist, so forgive me if I'm not using exact language here.... I have an ORBI router RBR50 and a satellite (if that's what it's called) RBS50. We have a Comcast modem which...
Jun 13, 2020Guru - Experienced User
If your ISP modem already has a router and wif built in, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Your Orbi should be good enough to handle wifi coverage and guest mode with out the addition of a extender.
Interested13 wrote:Hello - I'm not an IT specialist, so forgive me if I'm not using exact language here.... I have an ORBI router RBR50 and a satellite (if that's what it's called) RBS50. We have a Comcast modem which provides a duo 2.4 and 5.0 Ghz speed. I created a guest network through the Orbi app that is dedicated 2.4 so my landscape irrigation system (Rachio) would connect - it was disconnecting as the network fluxuated from 2.4 and 5 and Rachio told me I needed a dedicated 2.4 network. The name of the guest network is the same as the main 2.4/5.0 network with the word "guest" after it. I was wondering if I could get a wifi extender to make sure the 2.4 guest network got a stronger signal in the garage - was thinking I'd put it in the kitchen next to the garage.
Questions:
- Can I "boost" the signal of only one of these? The dedicated 2.4 guest OR the duo 2.4/5.0 main one? Or will the extender boost both? If it would only boost the 2.4 guest network, then if using wifi in the kitchen, we'd have to switch to the 2.4 guest network. If we do that, then maybe our Sonos (which runs off the 2.4/5.0 non-guest network) wouldn't work?
- If I buy the plug in extender (like the small size and idea of being able to move this around) - https://www.netgear.com/orbi/rbw30.aspx - which appears to only provide coverage for speeds up to 2.2 Gbps, will this slow down my whole network? I read this somewhere: "RBK50is AC3000 and the RBW30 is AC2200. The backhaul is also different and Tri-band vs Dual band. When mixing, your network speed capability will be limited to the max of your lowest device.
- If the above would slow my overall speed down, do I need to buy another RBS50 instead? I don't think I need the ports... I just want to plug into power; don't have hard wired internet cable anywhere but to the main RBR50....https://www.netgear.com/orbi/rbs50.aspx.
- So - OVERALL question is 1) which extender should I get and will it boost both the guest 2.4 and the regular 2.4/5.0 network?
- I just don't want to mess up the great network speeds we have with our regular 2.4/5.0 set up...
Thank you for any thoughts...
frustrateduser5
Jul 01, 2020Aspirant
Thank you for your response - i really appreciate it. I am thinking that it will be too complex for me to do anything but get a simple extender to reach the far side of the garage and hopefully not recognize the 5GHz frequency. If I play with all the Orbi settings to separate the two bands, I know something else will break - printers, thermostat, whatever and then I'll really be stuck because I just don't have the expertise (or patience) to fix it.
I just need a single band for this irrigation controller that has a stable, strong connection.
The irrigation company (Rachio) told me what the first person who responded to my post said, basically that any brand of "extender" (Netgear, TP-Link, D-Link, etc.) can connect to the Orbi WiFi and create new WiFi networks with different names for 2.4G and 5G that can be used to connect the landscape irrigation...The irrigation controller just needs a single band (either one) and a stable connection. Right now it drops during the day and reconnects at night - I'm guessing when we use less internet at night the signal gets stronger.)
I did read your post about a double NAT setup that might mess this all up and I might have that but I don't think I can troubleshoot that (I have a comcast modem that runs our phone and internet, then Orbi, then new extender, then irrigation controller). We have a 3500 sq ft two story house with the Orbi router downstairs next to the Comcast router in the center of the house (and the other Orbi directly upstairs) and then I'd have this new extender in the garage and then the irrigation controller there (that would be the only thing connected to the extender/new named wifi network). The garage controller is about 57 feet (walking) from the Orbi downstairs.
It seems that the Orbi will not naturally separate the 2.4 and 5.0 bands, so I guess I have to plug the extender in a place where it doesn't recognize the 5.0 but does the 2.4. Wish it weren't so complicated!
Anyway if you have any other thoughts, ideas, I'd welcome them! Thank you again.
- CrimpOnJul 01, 2020Guru - Experienced User
frustrateduser5 wrote:The irrigation company (Rachio) told me what the first person who responded to my post said, basically that any brand of "extender" (Netgear, TP-Link, D-Link, etc.) can connect to the Orbi WiFi and create new WiFi networks with different names for 2.4G and 5G that can be used to connect the landscape irrigation...The irrigation controller just needs a single band (either one) and a stable connection. Right now it drops during the day and reconnects at night - I'm guessing when we use less internet at night the signal gets stronger.)
The Rachio support person gave good advice. Purchase whatever "WiFi extender" is available and locate it where it will provide a good signal to the Rachio controller. Irrigation controllers consume practically no data, so a 2.4G only extender will be fine. Amazon sells many (many) WiFi extenders. I would tend to stick with one of the major brands. A TP-Link N300 would be fine. https://www.amazon.com/TP-Link-AC1750-inteligente-enrutadores-inal%C3%A1mbricos/dp/B0195Y0A42/ref=sr_1_4?dchild=1&keywords=wifi+extender&qid=1593667287&refinements=p_85%3A2470955011%2Cp_89%3ANETGEAR%7CTP-Link&rnid=2528832011&rps=1&sr=8-4
- frustrateduser5Jul 01, 2020Aspirant
Thank you so much.
