Interested13
Jun 12, 2020Follower
Best extender to get and how hard to install?
Hello - I'm not an IT specialist, so forgive me if I'm not using exact language here.... I have an ORBI router RBR50 and a satellite (if that's what it's called) RBS50. We have a Comcast modem which...
frustrateduser5
Jul 01, 2020Aspirant
Thank you so much for your response. Super helpful. Now I understand that the Orbi only uses a dual band.
The irrigation controller (Rachio) can only work with a single band and drops connection if the connections change back and forth between 2.4 and 5. I think I'll try a plug in Netgear extender (Netgear, hopefully for easy setup) near the garage and hope it'll be able to create a new, single 2.4 band for the irrigation controller. If not, if it creates two bands, I might be able to plug it in somewhere far enough away that it only recognizes the 2.4...?
Another person responded that I might have trouble due to a double NAT setup https://kb.netgear.com/30186/What-is-Double-NAT. I'm not sure if I have a double NAT setup. I have a single Comcast modem for our phone and internet that must have a built-in router because it broadcasts a 2.4 and 5.0 dual band as well, but I don't think anything is connected to it. Then the Orbi for all our devices, and then I'd have the new extender connected to the Irrigation controller only. Who knows? I wouldn't be able to fix that if that messes it all up...
Question for you: If I create a new wifi network with an extender, and that extender has a speed of 1200 mbps but the Orbi's speed is 3Gbps, will the new extender slow everything down? I'm hoping not, since it will be it's own network, but would love any additional thoughts, comments. Thank you again!
This is the one I'm thinking of getting https://www.amazon.com/NETGEAR-Wi-Fi-Range-Extender-EX6120/dp/B014YN7LVE/ref=asc_df_B014YN7LVE/?tag=hyprod-20&linkCode=df0&hvadid=198138936631&hvpos=&hvnetw=g&hvrand=14122893231199437192&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9033255&hvtargid=pla-352077305679&psc=1
CrimpOn
Jul 01, 2020Guru - Experienced User
That Netgear product should work fine. It just "costs more" because it creates both 2.4G and 5G WiFi extensions.
This issue of "Requires 2.4G" often causes more confusion than it should. If the device actually says, "Requires 2.4G WiFi", that usually means that the device has no 5G radio capability. That's sort of like saying, "Requires two AA batteries." You can have piles of C cells, D cells, AAA cells, and watch batteries, but the thing won't work unless you supply AA batteries.
Perhaps if you identify the exact model of irrigation controller, we can look at the User Manual and confirm what it requires.
- frustrateduser5Jul 01, 2020Aspirant
I was wrong - the Rachio supports both 2.4 and 5.0 but does need a single band - can't go back and forth between them. i thought I'd use am extender with a new SSID and use 2.4 since it's far from the router.: https://www.amazon.com/Rachio-Controller-Generation-Compatible-Intelligence/dp/B07CZ5K355/ref=redir_mobile_desktop?ie=UTF8&aaxitk=X5cEVZCI7DCiS-aspwwKMg&hsa_cr_id=8515648020801&ref_=sbx_be_s_sparkle_mcd_asin_0
And I'm also wondering if an extender with a speed of 1200 MBPS might slow down the Orbi with a 3000 MBPS speed. If I create a new SSID/wifi name for the extender then perhaps it won't mess up the Orbi SSID/wifi network name?
- CrimpOnJul 02, 2020Guru - Experienced User
frustrateduser5 wrote:And I'm also wondering if an extender with a speed of 1200 MBPS might slow down the Orbi with a 3000 MBPS speed. If I create a new SSID/wifi name for the extender then perhaps it won't mess up the Orbi SSID/wifi network name?
No. The extender appears as "just another device" to the Orbi and will have no effect on how the Orbi operates between units or with other devices.
