Jon_T
Jan 20, 2019Aspirant
Best Mesh Network for a Long House?
Which is the best Orbi config for me?
My house is long... around 90' long. And the base station needs to be located at the far end due to some wiring constraints. Connection is ~60M, so speed i...
Jan 21, 2019Guru - Experienced User
30 feet is recommended in between router and satellite(s) to begin with depending upon building materials.
My house is long... around 90' long. And the base station needs to be located at the far end due to some wiring constraints. Connection is ~60M, so speed is not extreme, but I want to make sure I can get that everywhere in the house. There are about 8 walls to contend with, from one end of the house to the other.
Your recommendations?
Thanks!
