giapanyo
Feb 19, 2021Initiate
best mesh system for wired home?
Hello I have wires running throughout my 3-story house (150m2), with A LOT of dead spots, and a 500mbps broadband which I may upgrade at some point in the future. Which mesh system would you reco...
Feb 19, 2021Guru - Experienced User
https://www.netgear.com/orbi/default.aspx
giapanyo wrote:Hello
I have wires running throughout my 3-story house (150m2), with A LOT of dead spots, and a 500mbps broadband which I may upgrade at some point in the future. Which mesh system would you recommend without breaking the bank? As I can use a Ethernet cable for backhaul, I don't necessarily need a tri-band: I would rather prioritise wifi speed performance.
Many thanks
