Foxeslink
Oct 13, 2019Aspirant
Best option for my house
Hey, so I have a large home and I want internet in certain areas. My house is Full Wired so I can have the best internet. The problem is I dont know what to Buy. I need 3 aps or Orbi system. Two of th...
Foxeslink
I was thinking in RKB50.
That would work seamlessly as they are wired ?
ekhalil
Oct 13, 2019Master
Yes, I have and RBK50 with wired backhaul and it works just fine. I have good wifi coverage all over the house, and at the same time have no dependency on how far the satellite is from the router as I'm using wired backhaul.
- FoxeslinkOct 13, 2019AspirantAnd i can connect the for example main orbi router to the satwllite in the orbi lan ports or I have to buy switch?
The configuration is easy?- ekhalilOct 13, 2019Master
.....The RBR50 has 3 x LAN ports and the RBS50 has 4 x LAN ports. You can use one of those ports on each node to connect the LAN ports between the nodes.
https://www.netgear.com/orbi/rbk50.aspx
Foxeslink wrote:
The configuration is easy?You can configure Orbi in few minutes using the Orbi app.
Just make sure that the ISP modem to which you connect Orbi is a "plain" modem with no router capability, so that the setup procedure will go smooth. :)
- FoxeslinkOct 13, 2019AspirantThank your for the help!
That Beijing said, do you the cheaper will serve for me? I think RBK 43 will be enough as it will be connect by ethernet. Need to think about this
