UNKNOWN51
Jan 22, 2019Aspirant
Best orbi settings/Advanced settings as of 2019?
Hi , just bought this router with 2sats/ Motorola 8600 docsis 3.1. I initially bought this to help with everyone on wifi through out the house. First off routers in my room at back of house, sat1 in...
- Jan 22, 2019
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try disabling the following and see:
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Enable Implicit Beam Forming and MIMO. Advanced Tab/Advanced Settings/Wireless settings.AP mode is meant for use when you have a ISP modem that has a built in router already or you have a router infront of the Orbi system that you prefer to use and you just want the Orbi to run as a AP. No wireless differences with Orbi in router or AP mode.
How are you testing wired speeds? Speedtest.net web site or app? Try different browsers and different PCs to compare.
First off routers in my room at back of house, sat1 in front of house,sat2 on first floor underneath my room.
First issue, between my router and sat1 in front room if I go in middle of two I lose call not sure what to do .
Also with my setup idk if router mode or AP mode is better.
Third issue, I have the 400down plan with Comcast I'm not pulling 400down hardwired maybe 320-350 normal?
Other then that I'm looking to tinker and find the best advance settings to mess with and how to go about it testing wise
Thanks in advanced
Jan 22, 2019Guru - Experienced User
Thanks in advanced
UNKNOWN51
Fw v2.2.1.210
Not really sure how big the home is in sq feet, but decent size 2 floor home about 50years old ..
Router from my room to front room is about 30 feet.
Auto, Il try these suggestions..
Testing thru fast.com/speedtest.net
- FURRYe38Jan 22, 2019Guru - Experienced User
Be sure to test wired speed connections first at the router.
