UNKNOWN51
Jan 22, 2019Aspirant
Best orbi settings/Advanced settings as of 2019?
Hi , just bought this router with 2sats/ Motorola 8600 docsis 3.1. I initially bought this to help with everyone on wifi through out the house. First off routers in my room at back of house, sat1 in...
- Jan 22, 2019
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try disabling the following and see:
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Enable Implicit Beam Forming and MIMO. Advanced Tab/Advanced Settings/Wireless settings.AP mode is meant for use when you have a ISP modem that has a built in router already or you have a router infront of the Orbi system that you prefer to use and you just want the Orbi to run as a AP. No wireless differences with Orbi in router or AP mode.
How are you testing wired speeds? Speedtest.net web site or app? Try different browsers and different PCs to compare.
First off routers in my room at back of house, sat1 in front of house,sat2 on first floor underneath my room.
First issue, between my router and sat1 in front room if I go in middle of two I lose call not sure what to do .
Also with my setup idk if router mode or AP mode is better.
Third issue, I have the 400down plan with Comcast I'm not pulling 400down hardwired maybe 320-350 normal?
Other then that I'm looking to tinker and find the best advance settings to mess with and how to go about it testing wise
Thanks in advanced
Jan 22, 2019Guru - Experienced User
Thanks in advanced
UNKNOWN51
Don't see option to check 40mz, so I just unchecked 20/40
Checked beam/mimo
Unchecked fast roam, Daisy chain, ipv6 is disabled now/ applied new setting
Speed test thru router management shows 470down/30up I don't see that when I do a speed test thru laptop/shield/xboxone
Checked beam/mimo
- FURRYe38Jan 22, 2019Guru - Experienced User
Unchecking 20/40Mhz sets 40Mhz only.
is laptop or xbox wired to router when testing or wireless? Wired is preferred for speed testing. Some wireless device may not fully support same speeds as wired due to design limiations from Mfr. If your getting at spec speeds on wired, then your good in the regard.
Checked beam/mimo
Speed test thru router management shows 470down/30up I don't see that when I do a speed test thru laptop/shield/xboxone- UNKNOWN51Jan 22, 2019AspirantYes hardwired on xboxonex ps4pro Nvidia shield. Don't have laptop upstairs.
But I can tell the instructions I was given are a hell lot better pulling 460-475down from Xbox and shield .. thanks guys
