captainjack58
Mar 21, 2019Star
Best orbi settings/Advanced settings as of 2019?
What would be the best Advanced Setting for this router RBK44 for fastest speeds! Also how often do they do firmware updates! I just hope this does not turn into a dead router like a lot of companies...
- Mar 21, 2019
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many? Channelization may depend on how many neighbors are near if, if any.
What WPA security modes are you using? Set WPA2 and AES only.Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain if you only have 1 satellite or satellites are placed in star formation with the base router, IPv6 if your ISP doesn't support native IPv6 and Set 20/40Mhz Coexistence to 40Mhz only.You can see the FW update history for your model here:
captainjack58
Mar 21, 2019Star
I turned on some of those settings as you mentioned, Also turned on my IPV6 setting and it seemed to improve things also! ISP supporting it. All in All much better and thank you!
Mar 21, 2019Guru - Experienced User
Enjoy. :smileywink:
