adikm
May 11, 2019Guide
Best orbi settings/Advanced settings as of 2019?
adikm
May 11, 2019Guide
- adikmMay 11, 2019Guide
my settings should i change anything for better relablity because thats my problem right now
- FURRYe38May 13, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
How many satellites do you have?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?- adikmMay 14, 2019Guide
I have the latest firmware I have 1 router and 1 satellite my house is 3500 squft I have 3 floors upstairs downstairs and basmenet but im upstairs right next to the satilete and the router is downstirs 50ft to 60ft away
- SW_May 15, 2019Prodigy
Hi adikm,
The best settings is Orbi default settings. You can enable those 3 Advanced settings for enhanced or new features if they don't wreak havoc in your WiFi network. Also, if your Satellites are within the WiFi range of your Orbi Router, please disable Daisy-Chain feature since it won't help and will only hurt.
BTW, what sort of reliable problem do you currently have with your Orbi setup?
