adikm
May 11, 2019Guide
Best orbi settings/Advanced settings as of 2019?
adikm
May 11, 2019Guide
my settings should i change anything for better relablity because thats my problem right now
May 13, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
How many satellites do you have?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
- adikmMay 14, 2019Guide
I have the latest firmware I have 1 router and 1 satellite my house is 3500 squft I have 3 floors upstairs downstairs and basmenet but im upstairs right next to the satilete and the router is downstirs 50ft to 60ft away
my channel for 2.4 ghz is auto
and my 5ghz is 48
- FURRYe38May 16, 2019Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz instead of Auto.
and my 5ghz is 48
- gr8shoMay 17, 2019VirtuosoMy preference here is get a tool like WiFi analyzer to scan for the cleanest channel. But in the case of 2.4GHz, it may be shoveling sand against the tide and allowing the hardware to switch on its own may be better, mostly because that band is likely more congested and the neighboring routers are probably also using default settings.
For 5GHz I make more of an effort to look at the spectrum to ensure no other router is stepping on the channel I’m using and manually controlling.
