champ712
Apr 19, 2018Aspirant
Best Orbi System for tall rowhome
Hi, I was hoping the community could help me with my wifi networking issues in my house, and recommend the appropriate Orbi system. I have a tall skinny house, so need wifi coverage "up", but do...
Apr 19, 2018Guru - Experienced User
Whats the sq footage of your home?
champ712
It is 2400 square feet, each floor is roughly 15 feet wide, and 40 feet deep
- FURRYe38Apr 19, 2018Guru - Experienced User
I would try one of the 40 series models. I have this one. 5000sq ft home. Place each unit at the opposite ends of the house from each other. 40 feet in between. Good coverage and performanc. I would do this at your place. main floor at each end of house...
- champ712Apr 19, 2018Aspirant
Thanks! Is there any downside to going with the RBK50 over the RBK40? The RBK50 is only about $30 more, with faster speeds. Thanks again
If you think you need faster speeds. Go for it. wireless range and coverage should be the same...
