DorkiOrbiFW
Jun 28, 2019Apprentice
Best Performance for Ring Devices (Orbi Config. Settings)
Hello Orbi Community, I am sure a lot of you use a Ring Video Doorbell, Ring Spotlight Cam, Ring Floodlight Cam, etc. on your Orbi network. I have seen a good majority of Orbi users that have Rin...
- Oct 19, 2019
Hello everyone,
There has been a lot that has happened since the last time I wrote.... so allow me to give a BIG explanation and a PERMANENT fix to ALL THIS CRAP!
- I truly thought that I did have defective spotlight cams, but turns out after a week and a half of the installation of all the replacements issued for my old units, I was back at square one with inconsistent launching of live view feeds.
- END RESULT: ISSUE PERSISTED; NOT DEFECTIVE CAMERAS
- I began to realize that I had an ongoing Orbi problem that was causing satellites to have syncing issues and dropping connection on devices connected to them at random despite my satellites all showing "GOOD" backhaul status. I kept waiting for a good and stable firmware to come out from Netgear to correct any bugs (if any) to correct the issues I was experiencing and firmware 2.3.5.30 came out. However, the issue still persisted and caused my Orbi to still operate incorrectly. I became desperate and was seriously about to RMA my entire system, but I also know that a factory reset after a major firmware update is sometimes needed to clear old and incompatible configurations from previous firmwares that cause the Orbi to misbehave.
- END RESULT: ISSUE PERSISTED; NOT BAD FIRMWARE
- Factory reset my entire system (Orbi router and satellites) and setup from scratch.
- So.... WTF was the solution you ask?
- My solution came from an article I stumbled upon that listed to run telnet commands I had yet to try to correct the issues I was experiencing. SW_'s tip and/or trick RESOLVED ALL issues I was experiencing. His trick assists in "fixing the Orbi WiFi network becoming unstable, random rebooting, and WiFi connectivity problems that occur after applying new Firmware Update(s)." However, I did modify his trick slightly. Please proceed to item number (5) for the proper solution to fix your ongoing issues with your Rings Spotlight Cams, other Ring devices, or hell, even any other regular device experiencing issues on your Orbi network.
- SOLUTION
- Go to the debug page of the satellite (EX: Unit_IP_Address/debug.htm) and click the checkbox near Telnet to ENABLE Telnet (do process on router and ALL satellites).
- Telnet into each satellite along with the router and type the following codes EXACTLY as shown and in the EXACT order (The codes may be executed on ALL Orbi routers and satellites, with the exception of the RBW30 satellite. If you have RBW30, please see alternate form.):
- config default
- config commit
- reboot
- Alternate Telnet Form - Applies to RBW30 Satellites Only
- reset
- reboot
- When you complete the above commands via telnet on your satellites, they should begin rebooting and pulse white.
- Factory reset the Orbi and setup from scratch. DO NOT utilize a backup file of an old configuration as you will defeat the purpose of this process and the issues willl then reoccur.
- Connect to the factory default SSID name that is now being broadcasted by your Orbi router and then go through the Orbi setup wizard. To get things up and running faster, I highly suggest hitting "skip" when it prompts you to setup satellites as you can do that later and it is best to wait to sync your satellites after you change Orbi's default advanced settings in order to have your Ring devices perform well.
- Configuring your Orbi for Ring Best Performance (this has been updated since last time I wrote in):
- BASIC -> Wireless, choose 40 for 5Ghz band (Offers the best signal and usually permits Orbi to have the best backhaul. Netgear recommends this channel for 5Ghz) and utilize whatever 2.4Ghz channel works best in your environment and your Ring devices. In my environment, I run 2.4Ghz band on Channel 3, and 5Ghz on Channel 40. Hit Apply when completed!
- ADVANCED -> Setup -> WAN Setup, under the section titled NAT filtering, select the OPEN radio button. Then, click on the checkbox to Disable SIP ALG. Hit Apply when completed!
- ADVANCED -> Setup -> LAN Setup, give ALL Ring devices address reservations (MUST). I also recommend giving all satellites an address reservation as well (though the satellite address reservation is optional and not required). Hit Apply when completed!
- ADVANCED -> Advanced Setup -> Wireless Settings, please ensure your configuration matches the configuration below. If you don't have your configuration the same as mine here, you will experience issues with your Ring devices. Hit Apply when completed!
- DISABLE WMM on BOTH 2.4Ghz and 5Ghz
- DISABLE MU-MIMO
- ENABLE Implicit Beamforming
- ENABLE Fast Roaming
- Add all your satellites back to your Orbi router to enable synchronization.
- Most Ring devices will reconnect on their own and be stable in about 2 days after the intensive troubleshooting on your Orbi network. However, if they do not, just go on outside and simply reconnect them to the Orbi network and you'll be just fine.
- ENJOY! I have had no issues to date! :smileyvery-happy:
*If you have any questions on how to access telnet, DM me and I'll gladly assist you or you can find how to do it via other forums listed within the community.
DorkiOrbiFW
Jun 29, 2019Apprentice
Drewmama wrote:
Thank you for this. After doing the steps, it didn't work so I unplugged my Echo show for a bit, reset my Ring doorbell and the two are playing nice so far. However, live view wasn't working. I would just get a black video. So I changed the 2.4 channel back to 1 and everything appears to be working as it should.
I eventually had to change my 2.4Ghz channel back to 1. Then, after rebooting the Orbi, a factory reset of each Ring device you have should correct the issue. Glad this helped you out! Ring devices are EXTREMELY sensitive to settings on the
Best,
Drewmama
Jun 29, 2019Guide
Ugh... My Echo show went back to not being able to display live view when asked. This is so frustrating.
- RrgirgisJun 30, 2019Starhey drewmama,
the above settings mentioned are very good
to make sure that you get good performance from your orbi. However this has been discussed in another thread; if you are using any Ring Battery device live view will only work on occasion no matter what setting you have put on your orbi. i have tried every setting combination and live view will not work consistently- again this is only on Ring battery devices, ring hardwired devices will live view fine with orbi.
There are 2 solution/work arounds to live view on Orbi for Ring Battery devices.
1. use a separate wifi router (in Access Point Mode) in conjunction with orbi to connect the ring battery device to. I am using an asus wifi router as an access point for just my two ring battery stick up cams and live view works flawlessly every time.
second option - its to get a ring chime pro and connect the ring battery device to it and that will solve the the live view issue.
i tried this option and it does work however its signal is weak and i needed more wifi signal power to reach my devices.
so ring plug in cameras/doorbell pro work with orbi without any addtional device.
if it is a battery ring camera you MUST use one of the two options to make live view work consistently!
please check through the last few pages of this thread below it goes over what i mentioned above in more detail and confirms that no orbi settings will make live view work on ring battery devices with out the two options above.
https://community.netgear.com/t5/Orbi/Orbi-and-Ring-products-issues/td-p/1500211
hope this helps- DorkiOrbiFWJun 30, 2019Apprentice
Drewmama, are those Ring devices your experiencing trouble with still connected to a satellite? If so, please continue to my next question.
What is your method for the Orbi backhaul (wireless or hardwired)? If it is wireless, change your 5Ghz channel to 40 as this promotes better backhaul strength and even Netgear recommends that channel for wireless backhaul as it’s a pretty stable channel for the most part.
Sidenote: Most Ring Doorbells are 5Ghz capable, so if your system uses a crappy 5Ghz channel, that could be a contributing factor that’s not allowing your live view to work. If your already utilizing channel 40 for 5Ghz, reach out to me directly or post here. Don’t listen to FURRYe38 as he does typical responses of reboots and change channels. I know the Ring devices inside and out and know how the Orbi works inside and out. As for Rrgirgis, he seems correct so far as the only Ring devices I have trouble with are ones that run on batteries. While I get his point of adding the Ring Chime to get those devices to work, you shouldn’t have to do this. I want answers and i will be reaching out to Ring AND Orbi to hopefully set things straight. I believe there is Firmware that needs fixing as I never used to have ANY problems whatsoever whether the device was wireless or hardwired.
Let me know and I’ll help you continue to troubleshoot!
Best,
- FURRYe38Jun 30, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Drewmama wrote:
Ugh... My Echo show went back to not being able to display live view when asked. This is so frustrating.- DorkiOrbiFWJun 30, 2019Apprentice
FURRYe38, please stop with your typical response. Those settings are comepletely invalid for this situation and for someone to put a working solution, only for you to put your crap that does the opposite, only confuses others more and is not a very wise choice.
Please don't tell others what to do. All responses are valid. If users don't wish to respond thats fine. I'll post as I see fit.
Thank you.
