DorkiOrbiFW
Jun 28, 2019Apprentice
Best Performance for Ring Devices (Orbi Config. Settings)
Hello Orbi Community, I am sure a lot of you use a Ring Video Doorbell, Ring Spotlight Cam, Ring Floodlight Cam, etc. on your Orbi network. I have seen a good majority of Orbi users that have Rin...
- Oct 19, 2019
Hello everyone,
There has been a lot that has happened since the last time I wrote.... so allow me to give a BIG explanation and a PERMANENT fix to ALL THIS CRAP!
- I truly thought that I did have defective spotlight cams, but turns out after a week and a half of the installation of all the replacements issued for my old units, I was back at square one with inconsistent launching of live view feeds.
- END RESULT: ISSUE PERSISTED; NOT DEFECTIVE CAMERAS
- I began to realize that I had an ongoing Orbi problem that was causing satellites to have syncing issues and dropping connection on devices connected to them at random despite my satellites all showing "GOOD" backhaul status. I kept waiting for a good and stable firmware to come out from Netgear to correct any bugs (if any) to correct the issues I was experiencing and firmware 2.3.5.30 came out. However, the issue still persisted and caused my Orbi to still operate incorrectly. I became desperate and was seriously about to RMA my entire system, but I also know that a factory reset after a major firmware update is sometimes needed to clear old and incompatible configurations from previous firmwares that cause the Orbi to misbehave.
- END RESULT: ISSUE PERSISTED; NOT BAD FIRMWARE
- Factory reset my entire system (Orbi router and satellites) and setup from scratch.
- So.... WTF was the solution you ask?
- My solution came from an article I stumbled upon that listed to run telnet commands I had yet to try to correct the issues I was experiencing. SW_'s tip and/or trick RESOLVED ALL issues I was experiencing. His trick assists in "fixing the Orbi WiFi network becoming unstable, random rebooting, and WiFi connectivity problems that occur after applying new Firmware Update(s)." However, I did modify his trick slightly. Please proceed to item number (5) for the proper solution to fix your ongoing issues with your Rings Spotlight Cams, other Ring devices, or hell, even any other regular device experiencing issues on your Orbi network.
- SOLUTION
- Go to the debug page of the satellite (EX: Unit_IP_Address/debug.htm) and click the checkbox near Telnet to ENABLE Telnet (do process on router and ALL satellites).
- Telnet into each satellite along with the router and type the following codes EXACTLY as shown and in the EXACT order (The codes may be executed on ALL Orbi routers and satellites, with the exception of the RBW30 satellite. If you have RBW30, please see alternate form.):
- config default
- config commit
- reboot
- Alternate Telnet Form - Applies to RBW30 Satellites Only
- reset
- reboot
- When you complete the above commands via telnet on your satellites, they should begin rebooting and pulse white.
- Factory reset the Orbi and setup from scratch. DO NOT utilize a backup file of an old configuration as you will defeat the purpose of this process and the issues willl then reoccur.
- Connect to the factory default SSID name that is now being broadcasted by your Orbi router and then go through the Orbi setup wizard. To get things up and running faster, I highly suggest hitting "skip" when it prompts you to setup satellites as you can do that later and it is best to wait to sync your satellites after you change Orbi's default advanced settings in order to have your Ring devices perform well.
- Configuring your Orbi for Ring Best Performance (this has been updated since last time I wrote in):
- BASIC -> Wireless, choose 40 for 5Ghz band (Offers the best signal and usually permits Orbi to have the best backhaul. Netgear recommends this channel for 5Ghz) and utilize whatever 2.4Ghz channel works best in your environment and your Ring devices. In my environment, I run 2.4Ghz band on Channel 3, and 5Ghz on Channel 40. Hit Apply when completed!
- ADVANCED -> Setup -> WAN Setup, under the section titled NAT filtering, select the OPEN radio button. Then, click on the checkbox to Disable SIP ALG. Hit Apply when completed!
- ADVANCED -> Setup -> LAN Setup, give ALL Ring devices address reservations (MUST). I also recommend giving all satellites an address reservation as well (though the satellite address reservation is optional and not required). Hit Apply when completed!
- ADVANCED -> Advanced Setup -> Wireless Settings, please ensure your configuration matches the configuration below. If you don't have your configuration the same as mine here, you will experience issues with your Ring devices. Hit Apply when completed!
- DISABLE WMM on BOTH 2.4Ghz and 5Ghz
- DISABLE MU-MIMO
- ENABLE Implicit Beamforming
- ENABLE Fast Roaming
- Add all your satellites back to your Orbi router to enable synchronization.
- Most Ring devices will reconnect on their own and be stable in about 2 days after the intensive troubleshooting on your Orbi network. However, if they do not, just go on outside and simply reconnect them to the Orbi network and you'll be just fine.
- ENJOY! I have had no issues to date! :smileyvery-happy:
*If you have any questions on how to access telnet, DM me and I'll gladly assist you or you can find how to do it via other forums listed within the community.
DorkiOrbiFW
Oct 19, 2019Apprentice
Hello everyone,
- SOLUTION
- config default
- config commit
- reboot
- reset
- reboot
- DISABLE MU-MIMO
xstussyone
Nov 05, 2019Initiate
Super frustrated for couple days now, thank you for your step by step. Setup was breezy, no hiccups so far, fast live connect, fast motion, fast ring, no lags whatsoever.
- FURRYe38Nov 05, 2019Guru - Experienced User
Just curious, what FW version are you using?
xstussyone wrote:
Super frustrated for couple days now, thank you for your step by step. Setup was breezy, no hiccups so far, fast live connect, fast motion, fast ring, no lags whatsoever.- xstussyoneNov 15, 2019InitiateTested out current settings Listed here which lasted a day or two then back to intermittent live view connection. Tried for several days witH close proximity to router with still same lag or no live view connection at all. Fix does cripple the speed of other devices (no support from net gear nor ring). Since then I’ve returned the two ring doorbells Purchased. Not worth the hassle if need to go that route in my opinion. Maybe will try the next tier ring doorbell that supports 5ghz . My floodlight and ring doorbell 1st gen works perfectly on reprogrammed stock settings for rbr50. Guess if not broke l, don’t fix it. But will definitely try the 5ghz.
- MOJOE3Nov 16, 2019Aspirant
I was on the phone with netgear and there is a new firmware called a Hot fix but I am having trouble downloading. Tech support said this is the fix to the ring issue. Did you try this one?
