Kessel81
Feb 16, 2020Follower
Best placement of Router + 2 Satellites? Please provide advice
Hello, I just bought the Orbi tri-band AC2200 wifi mesh system (RBK22). It came with the tri-band router (RBR20) + satellite (RBS20). I bought a third matching tri-band AC2200 satellite. I ...
Feb 17, 2020Guru - Experienced User
1400sq ft maybe too small for the RBR and two RBSs. I would first try the RBR and maybe 1 RBS and with good distance, probably work well.
Regarding your ISP modem:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Try option #2...
Kessel81 wrote:Hello,
I have a 1400 sqft. bungalow with a finished basement. 1 Gbps cable internet that came with the Hitron modem/router (all wifi functions turned off..Orbi gets no internet connection with the internet modem in bridge mode for some reason). The internet modem is located on the main floor near the entrance. I also have an ethernet cable running from this location down to the basement in the middle of the home to provide wifi coverage for the basement. I can have one connection there - in the middel of the home - in the basement. And the last Orbi satellite will be placed on the opposite end of the home in one of the bedrooms.
Case 1: Place the Orbi router near the entrance of the home (living room) by the internet modem. Run an ethernet cable from the Orbi router down to the basement and connect an Orbi satellite there with ethernet connection (middle of the home). And finally connect the 2nd Orbi Satellite by Wifi connection at the other end of the home in one of the bedrooms on the main floor.
Case 2: Place the Orbi router in the middle of the home in the basement and connect it to the internet modem with the ethernet cable that is running down from the main floor living room. Place the 1st Orbi Satellite in the living room up stairs with Wifi connection, and finally the 2nd Orbi satellite will be in the bedroom and connected through Wifi connection.
Which case would be better for me? Is it better to have the router in the middle and the two satellites on opposite ends? However, case 1 allows me to wire the Orbi router and also wire the 1st satellite by way of ethernet connection. Do the satellites connect only to the router or in case 1, would the 2nd satellite connect to the 1st wired satellite instead of bouncing back onto the router.
Thank you
Router Firmware Version
V2.3.5.26
