VFMass
May 10, 2019Aspirant
Best Practice for RBK50 Router and satellite
I just purchased the RBK50 WiFi router and single satellite extender. I still have dead zones as our business is 12,000 sq/ft on a single level. I currently have the router in a central location and ...
VFMass
plemans wrote:
VFMass wrote:
I just purchased the RBK50 WiFi router and single satellite extender. I still have dead zones as our business is 12,000 sq/ft on a single level. I currently have the router in a central location and the satellite extender within wifi range in one direction.
Question 1: Is it better to have it further away and connected by ethernet (5e connected via gigabit switch)?
I am most likely going to purchase a second satellite to extend the range.
Question 2: Can a satellite wirelessly piggyback off of the other wireless satellite or can it only connect to the router (as opposed to the satellite)? And/or, should it be hardwired to the satellite (or router) for better connectivity?
Thanks. I wish that Orbi had better documentation for best practices in setting up the network.
The Orbi's can daisy chain. Which means satellites can connect to each other. So it'd go RBR50---RBS50---RBS50
If you have the option of a wired backhaul, I'd use it. I have all my satellites hardwired in and my orbi setup works great.
// So, I could simply add an additional satellite to wirelessly connect to the other satellite. For a wired backhaul, it's OK to connect with switches in between or does it need to be cat 5e directly between RBR50/RBS50 or RBS50/RBS50?
May 10, 2019Guru - Experienced User
Yes you can add an additional satellite and it'll daisy chain back to the main router.
You can add switches in between Orbi's for connection. I've got a managed switch that was plug and play but some have reported issues with green switches or managed switches.
