Brownb01
Apr 22, 2019Aspirant
Best setup expanded home
Hello. I was wondering if I could get some help. Current setup - Internet provided by AT&T through a Netgear Nighthawk MR1100 with a Netgear 3200 in AP mode. I have the WiFi disabled on the MR1...
Apr 23, 2019Guru - Experienced User
Whats the model# of the NG 3200? R####?
30 feet is recommended in between base router and extenders or satellites to begin with depending upon building materials when wirelessly connected.
Seen users with 6 satellites connected to the base Orbi.
Brownb01
Apr 23, 2019Aspirant
AC3200
House is 1500 sq ft, but the property is 2 acres. I probably need about 200 ft in distance to reach my camera locations. I’ll need elevation of about 20 ft both up and down from the router location.
- FURRYe38Apr 23, 2019Guru - Experienced User
Ya, Orbi would not be a good system for your needs.
I would look into something more out doors supporting if these cameras are out doors. Use users have been working with some up to about 100 feet. Not sure of there full configurations and placement.
You may need some dedicated wired APs for this kind of configuration...
- Brownb01Apr 23, 2019AspirantThe cams I have today connect - it’s just spoty at times. I’m thinking an improved signal would help. I have outdoor shed with power where I was thinking about placing satellites. I was also thinking the Orbi Pro with an Outdoor satellite.
Wires AP’s are fine too. Are there some wired AP’s that would work with my current ac 3200?- FURRYe38Apr 23, 2019Guru - Experienced User
EX7700 or 8000. They work in either wired AP or wireless extender mode.
