locobryandean
Jan 28, 2020Aspirant
Best Strategy for changing wifi home password on network with tons of smart devices?
Hi, I need to update my password on our home WiFi network that has a bunch of sonos speakers and smart devices on it. Does anyone have a strategy on the best way to do this? I was thinking of naming...
Jan 28, 2020Guru - Experienced User
btw you'll need to change the ssid as well otherwise your devices aren't going to know which to connect to. Potentially they connect to the correct one and work or they connect to the one with a different password and won't connect.
If you plan on keeping the same ssid with a different password, you'll just need to change them all in one shot. or it'll be a nightmare of "which one works".
locobryandean
Yep, that was the plan. Update primary SSID and password and set guest network to old at the same time. Thanks!
