arcdancer
Jan 08, 2019Tutor
Best use of system
I run both a wired network and a wireless network.I have a Orbi RBR50, 2 RBS50s and a RBS40 which I have placed on my Property. The RBR50 is in my living room and is connected via Cat 5 to a switch. ...
Jan 08, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Whats the distance from the home to the and this shop? if it's with in about 300 feet, or less, you could run a LAN cable out from the home to the shop and then place the spare satellite there as a wired satellite connected to the Orbi in the home.
