robsquatch
Dec 17, 2018Tutor
Best way to add 2.4 gHz ONLY devices to Orbi mesh network?
I have many different devices on my network that can connect only to 2.4gHz. Obviously, with a mesh network, the broadcast frequency is automatically chosen in the background. Because I have such g...
- Dec 17, 2018
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
https://community.netgear.com/t5/Orbi/Have-to-keep-rebooting-my-RBR50/m-p/1658603/highlight/false#M44420
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
robsquatch wrote:
I have many different devices on my network that can connect only to 2.4gHz. Obviously, with a mesh network, the broadcast frequency is automatically chosen in the background. Because I have such good coverage everywhere in my house now, it is impossible to force these devices on to the slower frequency. This is the case with my security cameras, wireless thermometers, etc. The only solution I seem to find is one that involves changing command lines which seems ridiculous to me. Is there a quick and easy way to turn off 5gHz temporarily to program new devices? I have also tried turning down the 5gHz power as well, with no progress.
randomousity
Dec 17, 2018Luminary
I don't know this for sure, but I have a theory that the problem lies with the apps for the smart devices. I'm probably not an "expert" within the scope of how you meant it.
Something like, when you're configuring a smart device via the accompanying app, it's possible that the app is looking at the BSSID, BSS, etc., the phone is using (e.g., 5GHz), and, while the app (should) obviously know that the device is only 2.4GHz-capable (not always the case, as some apps may work for multiple devices, only a subset of which are 2.4GHz-only), the app may be collecting and transmitting to the smart device settings the device is physically incapable of putting to use. This could be happening due to sloppy programming on the app devs' part, due in part to the unanticipated use of the same SSID for both the 2.4GHz and 5GHz WLANs, which I don't believe was very common prior to mesh systems (e.g., my previous router, when naming the SSID as [arbitary name X], would apply that to the 2.4GHz WLAN, and then also create X-5G and X-guest by default, resulting in three WLANs with unique names).
This could be happening because, during the configuration, the user tells the app which WLAN to use, and then the app queries the phone for the details of that WLAN, referenced by SSID, and the phone replies with the 5GHz details, since that's what the phone is connected to, not realizing the app actually needs the 2.4GHz details instead, since the SSID is ambiguous, existing on both the 2.4GHz and 5GHz bands.
Alternatively, it could be something like, the app asks the user for the (2.4GHz) SSID, sees that it's a valid 2.4GHz WLAN, despite the phone being connected to the matching 5GHz WLAN, and then tells the phone to connect to the smart device via this SSID, without specifying that the phone use the 2.4GHz version of the WLAN. The app sees that X is a 2.4GHz WLAN, but the phone transmits the configuration settings over the 5GHz WLAN by the same name, thus never reaching the 2.4GHz-only device, and resulting in a configuration failure.
CrimpOn
Dec 17, 2018Guru - Experienced User
I appologize for having hijacked the original thread. Perhaps we could be more helpful if robsquatch identified the specific 2.4G devices which are difficult to connect. That information may provide helpful clues.
When devices come "out of the box", they can wake up and detect SSID's, but they have no idea which SSID should be connected to, and they have no password to supply. Somehow, they have to get that information in order to connect successfully. With devices that offer an "input mechanism", such as a keyboard, camera, or ethernet port, the user can provide the SSID and password through that input. (My Reolink battery camera app creates a smart bar code which I hold in front of the camera. The cameras with ethernet have to be connected to a computer the first time. My security system uses the key pad to select the SSID and (tediously) input the password.)
I doubt that a smart phone app providing SSID and password for the Orbi connection (somehow) to a device can be the problem. Orbi uses the same SSID and password for both 2.4G and 5G. The device would know, "look for this SSID and give it this password." The device sees only 2.4G networks. Finds the Orbi 2.4G signal. Gives it the password. And, "voila. connected."
Something about the device firmware, the smart phone, and the app isn't working. Maybe some phones restrict what apps can do in regard to WiFi, so the app fails to find the device. Maybe..... (a lot of things). When it works, it's slick. My TP-Link smart plug setup was complete in under 10 minutes using an Android phone connected to Orbi at 5G, including setting up the Kasa account and updating the plug firmware. But then, TP-Link makes computer devices, not doorbells or food cookers.
I Googled the Ring doorbell and found comments wondering if (a) some devices can connect only on channels 1, 6, or 11, or (b) some devices may "stick" to their first channel and not realize that the WiFi access point has changed to another. Seems pretty dumb (to me), but might be the case.
Again, sorry I haven't done anything to help.
- robsquatchDec 17, 2018TutorAny feedback is helpful :)
The specific devices giving me problems are as follows:
1) La Crosse WiFi weather station
2) Amazon cloud cam
Both manuals specially call out 2.4 only and these are the only two devices giving me problems.- FURRYe38Dec 17, 2018Guru - Experienced User
Try turning down the 5Ghz power on the Orbi to 25% to see if this might help. Try the other suggestions as well.
What channels does the Mfrs of these devices recommend using on 2.4Ghz? Try manual 1, 6 or 11
What security modes does the Mfrs of these devices recommend using? WPA or WPA2? TPIK or AES?
2) Amazon cloud cam
Both manuals specially call out 2.4 only and these are the only two devices giving me problems.- robsquatchDec 17, 2018TutorI tried turning down the power as well as unplugging the closest satellites with no success. I didn’t try changing the channel. I will try that tonight. Thank you!!
- ekhalilDec 17, 2018Master
2) Amazon cloud cam
Both manuals specially call out 2.4 only and these are the only two devices giving me problems.I think this issue happens only when the phone (where the app is) connects to the 5GHz band and the device is trying to access the 2.4 GHz band.
This is a bad design of the app and not an Orbi issue.
If you have a very old phone that only supports 2.4 GHz then you should smoothly attach your devices. :)
- CrimpOnDec 17, 2018Guru - Experienced User
This thread has certainly "opened my eyes" to how things get connected. Amazon's Cloud Cam app requires a Bluetooth connection to talk to the camera for setup. Their troubleshooting advice ( https://www.amazon.com/gp/help/customer/display.html?nodeId=GSE2KHKMAWFLGLPZ ) suggests removing the "mesh" from the problem (turning off satellites). The video is pretty slick. At what part of the setup does the app fail? Like, does it "see" the Orbi SSID? Does it ask for the password and then die?
- randomousityDec 17, 2018Luminary
I understand what you're saying, and I agree that this shouldn't be an issue. But it really depends on how the app configures the device. If the app just tells the device "connect to [SSID] using [password]," there should be no issue. But, if the app says something like, "connect to AP with [MAC address] on [SSID] using [password]," where the MAC is the Orbi's 5G MAC, the smart device will be unable to complete this, and will fail. And, if the phone sees both 2.4G [SSID] and 5G [SSID] and the app just asks for the details of [SSID], it's ambiguous, and the phone might naturally reply with the 5G details, that being the WLAN it was most recently connected to, and, possibly, the only version of [SSID] the phone has ever connected to. And yes, it could be some security setting on the phone that limits what the OS can give to the app regarding WLAN details. This is why my guess is that, while we know the device only needs [SSID] and [password], and, superficially, it looks like the app is only passing those along to the device, there must be something else at play here.
I don't think it can be that the devices can only connect to channels 1, 6, or 11, otherwise disabling the 5G WLAN on the Orbi via telnet wouldn't work for anyone, which it seems to do. It also wouldn't explain why giving the 2.4G and 5G WLANs different SSIDs would work for people. I've also not seen any solutions saying to set the 2.4G channel on Orbi to 1, 6, or 11 (as opposed to either auto or one of the other 8 channels in 2-5 or 7-10) and those working for people with Orbis. But who knows?
At any rate, I suspect the issue is either with the devices and their firmware, and/or the app. Even if there's an OS limitation on what wifi info an app can get from the OS, that should be irrelevant, because the app should only be passing on [SSID] and [password] to the device, and that should be all the device needs to successfully connect, and it should be possible to connect the smart device to a WLAN the phone isn't and has never connected to. The app using a GUI and pulling the available WLAN SSIDs from the OS should only save the user some typing and eliminate transcription errors.
C'est la vie.
