StephanExtreme
Mar 29, 2022Aspirant
Best way to configure home network of Orbi RBR50 mesh, At&t BGW210 gateway, and apple airport extrem
I have been trying to configure the best network settings for gaming (xbox) for a while now between the Orbi and AT&T router, and have just about tried everything I can think of. I used to get massiv...
Mar 30, 2022Guru - Experienced User
Your ISP modem configuration would need to be reviewed since it's handling all the routing and NAT configurations there.
Something to contact the ISP about. Orbi is just passing data thru in AP mode.
- StephanExtremeMar 31, 2022Aspirant
So i ended up trying to see how the network performs if the orbi is in router mode, boom, everything is fixed. Packet loss went down to ~0% when before it was 4-12% and mbps went up close to our ISP's max. But now i have to deal with NAT issues for my xbox. I obviously don't want to put the obi back in AP mode anymore so how can i get my NAT type to open? I am trying to do IP passthrough in my gateway settings to the orbi, but i dont thinkl the IP address listed for the orbi is correct because i can't even access the orbi's settings using that address in my browser. Any tips? Thank you.
