ShankarHokie
Dec 26, 2020Apprentice
Best way to connect USB 3.0 external drive to Orbi ethernet post
Hello, Update: The new house was hardwired with Cat 6 cables in every room. Have the Orbi in the basement paired with a Netgear CM100 modem from Costco and an unmanageded Netgear Gigabit switch. ...
Dec 26, 2020Guru - Experienced User
External USB drives are not supported on Orbi systems.
You best way to get it shared out would be connect it to a PC or laptop that can be accessed alwasys or migrage to actual NAS storage. Once you go NAS, you won't go back.
