ShankarHokie
Dec 26, 2020Apprentice
Best way to connect USB 3.0 external drive to Orbi ethernet post
Hello, Update: The new house was hardwired with Cat 6 cables in every room. Have the Orbi in the basement paired with a Netgear CM100 modem from Costco and an unmanageded Netgear Gigabit switch. ...
alokeprasad
Dec 27, 2020Mentor
Fully endorse the NAS option. Word of advice: buy a NAS with more drive bays than you think you need.
Storage needs expands to fill the space available :smileyhappy:
I found this gizmo by googling. I have no idea how reliable this is. Maybe you can find a vendor with good return policy...
ShankarHokie
Dec 27, 2020Apprentice
Thanks alokeprasad : I found that too. That's what prompted me to ask if there is a Netgear Solution. I am inclined to try it.
I will also keep in mind the NAS recommendation from everyone.
