alokeprasad
Mar 22, 2025Mentor
Best way to factory reset a disconnected RBR and RBS 50's
Hi all, I have powered off and disconnected my RBR and 2 RBS 53's. These were replaced by another (newer) mesh system. The new network is functional. Unfortunately, before switching over to th...
CrimpOn
Mar 22, 2025Guru - Experienced User
When Factory Reset, they return to the WiFi credentials printed on the label (bottom of the case). Is that what is happening?
alokeprasad
Mar 22, 2025Mentor
When I last did that, I was using the Orbi's. The units reconnected and was accessible through the web interface like the reset did not happen. Is there a LED color or flashing lights that indicates a successful reset?
I have the RBS's still connected via wired (Ethernet), but now to the eero 7 Max. They are still functional!! The ring light turned blue and is now off. The devices connected to the RBS are on the network. I'm sure the WiFi on the RBS's are off (I used the same SSID w the eero that I was using w the Orbi.. so I can't tell for sure.).
The RBS's can be used as 1 gigabit switches!! The eero shows the satellite RBS as connected device
I might just keep them đ
- CrimpOnMar 22, 2025Guru - Experienced User
- alokeprasadMar 22, 2025Mentor
The default password is working on the satellites (that is the only Orbi that's connected to the eero network (via ethernet).
The web interface of the Orbi satellite is showing all the devices and wireless connection types. How do I interpret this? Is it possible that the WiFi features of the RBS is functional even when the RBS is connected to the eero 7 Max?
Wired connections I can understand. But WiFi cannot be inter-operational between Orbi and eero, can it?
Please see the screenshot of the RBS.
This satellite is the only Orbi unit that is powered on, correct?
