alokeprasad
Mar 22, 2025Mentor
Best way to factory reset a disconnected RBR and RBS 50's
Hi all, I have powered off and disconnected my RBR and 2 RBS 53's. These were replaced by another (newer) mesh system. The new network is functional. Unfortunately, before switching over to th...
CrimpOn
Mar 22, 2025Guru - Experienced User
This satellite is the only Orbi unit that is powered on, correct?
alokeprasad
Mar 22, 2025Mentor
Yes. As single RBS is the only device hanging off the Ethernet (connected to the eero Max 7 network). The eero network has 2 devices (eero Max 7 base and satellites are all the same) connected by Ethernet.
You may have noticed that I prefer Ethernet over WiFi to the extent possible. đ
The screenshot is that of that RBS.
