Naor1999
Apr 03, 2019Aspirant
Best way to setup RBR50/RBS50 with Nighthawk x8
Does anyone know the best way I can hook up the following equipment (wirelessly) for best signal output? I have the orbi rbr50 router, orbi rbs50 satellite and the nighthawk x8 ac5300 router.
Apr 03, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
The R series router can only run in Router, AP or wireless bridge mode. It can be connected as a wireless bridge with the Orbi if you have wired devices to connect to it when in this mode.
Naor1999
- ORBI - v2.3.1.44
- X8 - I don’t know how to access it....
- Orbi is connected to “Arris 6183”
- 50’ in my home.
- I’m not sure what any of those modes are. For me, it does not matter how the 3 units are hooked up. Whichever works best will work for me.
- ORBI - v2.3.1.44
- 50’ in my home.
