Naor1999
Apr 03, 2019Aspirant
Best way to setup RBR50/RBS50 with Nighthawk x8
Does anyone know the best way I can hook up the following equipment (wirelessly) for best signal output? I have the orbi rbr50 router, orbi rbs50 satellite and the nighthawk x8 ac5300 router.
Naor1999
Putting it into wireless bridge mode will enable the nighthawk to act as an additional satellite?
Apr 03, 2019Guru - Experienced User
No, The R series routers don't support repeater or extender modes. Only router, AP which means it needs a LAN cable between the main host router and itself. Wireless bridge mode means it's only connected to the main host wifi. Doesn't provide any wireless signal for wireless devices and only LAN cable devices can connect to the back of the unit when in wireless bridge mode.
- Naor1999Apr 03, 2019AspirantCan I switch that and use the Orbi router and orbi satellite as active satellites of the X8?
- FURRYe38Apr 03, 2019Guru - Experienced User
No, the RBS need to be connected to the Orbi base for complete wireless MESH configuration.
https://www.speedguide.net/faq/wireless-repeater-extender-vs-access-point-385
