Laurent1630
Mar 12, 2019Aspirant
Best Wifi option for my house
Hello,
I want to install a full wifi coverage in my house and I don't know what is the best device folr me.
I have a 3 floors house with a wired network in almost all the room. What I wan...
Laurent1630
Thanks guys for your answers, you're a great community and it really helps but...
I'm still not sure what I need. ORBI is definitively the choice, now the question about the model.
My house is about 750 square foot (70 m2) by floor, 3 floors. My idea is to install the base in the basement (where is the router) and then, a satellite on the ground and 1st floor. If they are linked with Ethernet, I think that a RBK20 could be enough. The difference of price between 20 and 50 is quite important and even if I want a good solution, I won’t pay twice for a 10% gain.
Sorry for the typo and english mistakes, I'm a french speaker from Switzerland ;o)
- FURRYe38Mar 12, 2019Guru - Experienced User
If ethernet connected, the 20 series should be good for your size of home.
I would try to make the Orbi base on the main floor if possible for best wifi singal propagation. Basements are not idea and concrete materials can cause singal problems.
- plemansMar 12, 2019Guru - Experienced User
Agreed with this. Between concrete in basements and HVAC ducting there are plenty more signal issues in a basement. Shoot for the main floor with the main unit and hardwire the rest if possible.
- FURRYe38Mar 13, 2019Guru - Experienced User
Let us know how it turns out. :smileywink:
