jmbarbs
Jun 20, 2017Apprentice
beta firmware v1.11.0.8
Have had the Beta v1.11.0.8 installed for nearly a week and massive improvements to how my wifi is now performing. In particuar for the first time since purchase i can now have beam forming turned on...
Landerx
Jun 23, 2017Apprentice
I hope the beta firmware fixes the disconnect issues.
Ed.
kadmus11
Jun 25, 2017Star
Well, after a few days I can say that the ios disconnects have stopped.
However, my android phone has started getting disconnects again. So it's better but it still hasn't fixed everything.
- LanderxJun 25, 2017Apprentice
How did you get the beta firmware? I pm'd the moderator but never got it.
- kadmus11Jun 25, 2017Star
I got it through pm with Darren. Then I got a link from Netgear support. I think even if he doesn't answer you, he passes it on.
- LeBulletJun 25, 2017Apprentice
So, I've been using v1.11.0.8 and I have to say it's really been a very good step forwards.
beyond a few heat camera drops a day, (no beam forming here), most of my other issues of the last few months are resolved or greatly improved at least. No system reboots, restarts or soft reboots, all been good.
ive noted much improved IPad battery drain Sonos works great, as does my Hue syste,, my SkyQ now works as it should again, all the download speeds are good, and I'm generally pleased with the progress.
Thanks guys, can you advise when we should actually upgrade our firmware, when the fixes are made mainstream please?
kindest,
AG
