mikerpalmer
Jul 05, 2017Tutor
Beta Firmware
I am having all kinds of issues with the latest update. I am getting disconnects and speed issues. I was running an older version of firmware but the system will not allow me to downgrade back. It au...
- Jul 18, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please post the issues you are having or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Vmk16
Jul 05, 2017Star
Hello mikerpalmer ,
Which orbi model are you using, Is it RBR40 or RBR50 ?
Are you getting disconnection and speed issue on all devices ?
For RBR50 I GUESS THERE IS A BETA FIRMWARE NOT SURE ABOUT RBR40 . YOU CAN REACH OUT THE ORBI TECH SUPPORT @ 888NETGEAR .
- mikerpalmerJul 05, 2017Tutor
It's the RBR50. I am noticing my iPad will drop wifi and then reconnect after about 30 seconds. I have a nest cam which disconnects every so often. Also, noticed my MacBook was connected to wifi but could not reach anything on my network (pings failed) until I turned wifi off/on on my MacBook.
