mikerpalmer
Jul 05, 2017Tutor
Beta Firmware
I am having all kinds of issues with the latest update. I am getting disconnects and speed issues. I was running an older version of firmware but the system will not allow me to downgrade back. It au...
- Jul 18, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please post the issues you are having or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Vmk16
Jul 06, 2017Star
Hello DaoDaoJ ,
Yes you are right the latest beta firmware is V1.12.0.16 .Which will an official one soon.
Doug-48051
Jul 06, 2017Luminary
Does anyone have a push date for V1.12.0.16? I have beamForming turned on, will this be an issue if the FW is automatically updated?
- peteytestingJul 06, 2017Hero
not at this time
if beam forming is working for you now it should work when new fw is pushed
- JMU1998Jul 06, 2017Luminary
Can we turn on the MU-MIMO feature on yet? Or do we need to wait for the next Firmware? (assuming current Beta has it fixed).
i have had mine on for ages and nothing has been a problem , this you will only know if you turn on and test in your location , if it doesnt cause issues then leave it on , if it does cause issue leave it off for now and report the issues
