mikerpalmer
Jul 05, 2017Tutor
Beta Firmware
I am having all kinds of issues with the latest update. I am getting disconnects and speed issues. I was running an older version of firmware but the system will not allow me to downgrade back. It au...
- Jul 18, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please post the issues you are having or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Doug-48051
Jul 06, 2017Luminary
Does anyone have a push date for V1.12.0.16? I have beamForming turned on, will this be an issue if the FW is automatically updated?
peteytesting
Jul 06, 2017Hero
not at this time
if beam forming is working for you now it should work when new fw is pushed
- JMU1998Jul 06, 2017Luminary
Can we turn on the MU-MIMO feature on yet? Or do we need to wait for the next Firmware? (assuming current Beta has it fixed).
- peteytestingJul 06, 2017Hero
i have had mine on for ages and nothing has been a problem , this you will only know if you turn on and test in your location , if it doesnt cause issues then leave it on , if it does cause issue leave it off for now and report the issues
- Yld2robJul 07, 2017Luminary
I am on beta 1.12.0.12. MU-MIMO and beamforming on. No disconnects. I have over 60 devices connected including Dropcams and I have been running the beta for a week with no issues. I think we may finally have a winner.
- Doug-48051Jul 07, 2017Luminary
Hearing good things about beta 1.12.0.12. I am getting SAT drops. Lets hope they PUSH out as auto update soon.
