contenderv07
Feb 06, 2020Aspirant
BGW210 ATT Fiber
Hey everyone, I just got an AC3000 and 2 satellites and I'm having some trouble getting connected. I informed ATT that I was moving from their wireless to the Orbi, and they said they would make chan...
Feb 06, 2020Guru - Experienced User
Ensure you try one of the options listed since your ISP service HW has built in router:
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- contenderv07Feb 06, 2020Aspirant
thank you for the response.. I am on the latest firmware version (updated it with support). I have disabled all of the wifi radios on the ATT router. I'm at work but will check it out whne I get home. Thanks for the response!
- FURRYe38Feb 06, 2020Guru - Experienced User
Latest being v2.5.1.8? Just making sure.
yes, thats correct. Just to get more context, I did take this pic when I was directly connected to the orbi router. I just found it strange that it would "see" the satellite (could get the MAC address), but not pull an IP for either, and label one of them as "unknown"
